How big of wire do i need????
i have a rockford 400s how big of power/ground wire do i need to use it gets preety hott i was wondering if the wire was 2 small.
im usin 10 now??????????
Username: N2audio
Lawrence, Ks USA
Post Number: 590
it won't have any effect on how hot the amp runs, but you'd be better off running 8 ga with that amp.
Username: N2audio
Lawrence, Ks USA
Post Number: 592
http://www.bcae1.com/images/swfs/wirepowercalculator.swf
(your amp should be about 60% on efficiency)
do u know how many wats that amp is puting out i got it frome a friend the part #is 300s.
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 97
well if its 300s, its probly 300 x 1 at 4 ohms, but just google it to find out. Also, if your cars lights dim at all, a higher gauge wire could help. I used to have 8 gauge wire ran to a 1000 watt amp and needless to say there were issues. So I changed it to 4 gauge wire and since then the lights haven't been dimming as bad. I think higher gauge wire helps the capacitors inside in the amp hold a current much better; thus less dimming in your lights.
it's in a house but i havent had any problems with it yet. but over heating and it makes a really hi pitch eeeeeeeeeeeeeeeeeeeeeeeeee sometimes do u know wat the sound is anybody? thnx.
wat is that eeeeeeeeeeee any body??????
