Glasswolf, Rovin, Chauncey..... HELP!!!!
Username: Liqdfire3
Lee high acres, Florida
Post Number: 41
i just baught one of the viper d1200.1's off ikesound.com and when the package arrived, i looked at all the terminals and everything and where all the wires are suppost to hook to the amp, there isnt anything except posts. the terminals are there, but they are just gold plated posts. i know this sounds confusing. im trying to word this as best as i can. how the hell am i suppost to hook up the subs, power, ground, and remote now?
Username: James1115
Ct
Post Number: 5102
I believe there are plugs that go with that amp it didnt come with them?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5623
can u take pics
Username: Liqdfire3
Post Number: 42
well i baught it for a friend. its at his house. i might be able to take some pics tomorrow. james, u know where i can get the plugs?
Post Number: 5627
I no what ur talking about, did the posts come with screws???
Username: Liqdfire3
Post Number: 43
not that i saw. i can look at it better tomorrow. i am planning on doing his install this weekend hopefully if the box comes in. but when i saw that d@mn amp, i flipped out. i dunno what to do. how can they send me an amp without the posts?
Username: James1115
Ct
Post Number: 5107
http://cgi.ebay.com/DEI-Viper-Class-D-plug-kit-1200-1-600-1-300-1_W0QQitemZ57915 23101QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem thats what you need man:-)
That sucks. Check for DEI or Viper plug kit
Post Number: 5632
I really thought it would come with 1 though, u should contact them and ask them about it
Username: James1115
Ct
Post Number: 5108
yeah they should have sent it. re check the box and make sure they arnt taped to the inside of the box. my PPI's plugs came in a small sealed little pouch thing, very hard to find and very easy to throw out.
Username: Rovin
Trinidad & T...
Post Number: 5660
well i see u guys got it covered - good job , James !.....
Username: James1115
Ct
Post Number: 5111
yeah I figured I would jump in and try to get my feet wet and answer my first question:-) it really want that bad! :-)
Username: Liqdfire3
Post Number: 44
james thanx man. u were a big help. im bout to go over to my friends ouse now to look at the box so hopefully it is in there. i really dont want to buy a new set of plugs. i appreciate everything guys!
