The best amp
chancc
what would be the best amp to run to these subs (personally i was thinking the power acoustic LT 1440) if theres sumthin better it that price rangg wht would u recomend
1200 Watts MAX Power
600 Watts RMS Power
Frequency Response: 23Hz - 120KHz
Sensitivity: 94dB
Rubber Surround
COC p-p Cone
Chromed Die-Cast Aluminum Basket
2.5" 4 Ohms 4-Layer Aluminum Dual Voice Coil
Nomex Spider
110 oz. Magnet
Username: Rovin
Trinidad & T...
Post Number: 5573
orion 1200d
or
kicker 1200
Username: Scootzilla
Indianapolis, IN USA
Maybe this will sound stupid.I just got a Kenwood 8152 amp from HHgregg for 149 onsale.Kust letting you know just in case you dont have a boat load of money for the orion or kicker that all.Plus it goes for 269 at cardomain.Might want to check it out.
Scoot
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5459
viper 1200.1, made by the same company that makes Orion and Directed and its only $125
