How many cvr's can kx1200.1 push
Username: Night_mirage
AmmanJordan
Post Number: 100
i bought yasterday kx1200.1
and two of cvr's 12" dvc 4ohm
i would like to buy another one can kx1200.1 push three of them >
thanks
Username: Pelona
Post Number: 531
yes but it can also be used for two cvrs
AmmanJordan
Post Number: 101
okay but does kx1200 will do the same worke on three or less
Username: Pelona
Post Number: 532
i dont know about that. but i would stay with 2 cvrs so you can get them at full excursion and itll be easier to install.
and i think the ohms wont be right if you use 3 cvrs.
AmmanJordan
Post Number: 102
thanks Pelon
i also think so .
cause cvr is 400 RMS and kx1200 push @4ohm 300 w
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11062
ideally you'd run four dual 2-ohm coil CVRs on that amp.
get 300 watts each at 1 ohm.
Username: Pelona
Post Number: 535
i dont know. all that ohms sh!t confuses me.
AmmanJordan
Post Number: 105
GlassWolf i did'nt understand you
would you give me more details .
Username: Tjmutlow
Post Number: 1462
take 4 of the comp vrs dual 2ohms and wire them series/parallel see www.the12volt.com under woofer wiring for the diagram.
Username: Thunderforce
Netherlands
If you use 4 DVC 4ohm Cvrs youre KX1200.1 wil go up in smoke, it will see a 0,5ohm load with 4 or a 0,667ohm load with 3 subs.
KX1200.1 smells very bad
AmmanJordan
Post Number: 110
okay what about
SX1250.1
can i wire three 4ohm on it
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11093
in straight parallel, three dual 4 ohm coil subs would be a .666 ohm load.
the amp would shut down and go into protection mode.
Username: Tjmutlow
Post Number: 1470
you can run 4 dual4 to a 2ohm load. and then run a zx series amp like the 1500.1
Los Angeles, CA USA
Post Number: 2396
"in straight parallel, three dual 4 ohm coil subs would be a .666 ohm load.
the amp would shut down and go into protection mode. "
that whole statement just sounds freaky.
Username: B101
Queen City, NC USA
Post Number: 1081
lol.
Chad .666 isnt too bad; but will probrably fry the hell out of that kicker amp. He would have to use better equipment. Isnt that thing 2ohm stable?
AmmanJordan
Post Number: 117
no its 1 ohm
i will put just two 12" cvr 2ohm
is that okay
Netherlands
if you want to play at 0.667 you could better take a modified MTX 1501D.
if you link 2 of them at 16volt they give over 6000W of power
AmmanJordan
Post Number: 119
Thamks Thunder
but i just want kicker ..
if you put 2 dual 2 ohm subs you will get 2ohm or a .5ohm load depending on how you wire it or if you put 2 dual 4 ohm subs you will get 1ohm or a 4ohm load depending on how you wire it!
AmmanJordan
Post Number: 120
anonymous
i will put 2 cvr dual 4ohm on sx1250.1 amp
