To preout or Not to preout
Username: Lewass
Boomfield Hills, MI USA
Post Number: 552
Yo. I've got a DEH-P4600MP, no sub preouts. How much of a difference in bass response will I notice if I bought, lets say, a Premier 860?
Feeding ~1000wrms to 3 10's ported. Check profile if more info needed.
Also, what kind of sub control features is the 860 rockin?
Username: Tjmutlow
Post Number: 1856
alot, the voltage on the 860 is high on the preouts
Username: Matt12490
Benicia, California USA
Post Number: 566
I am also thinking about getting this unit and wondering the same.
Username: Makmillion
United States
Post Number: 13
The deh-p860mp has incredible output control.. Mine is hooked to a TX1005D Hifonics and I can control the amp from my dash, on/off, barely on all the way to "my eyes are vibrating!".
There is no doubt you will notice the difference.
The 860 has alot of sub controls:
50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct
You can also put the unit into pro mode which will give you another array of options to control the outputs.
Username: Lewass
Post Number: 559
Oooooh baby, that sounds perfect.
Username: Rovin
Trinidad & T...
Post Number: 7097
GR8 HU - i too own a 860
also has a 13 band built in EQ & a sub preout $aves u from actualy needing a xover cause it filters darn good as is ........
