Help Recommend me some subs for 2 - aw8002t
rochester2580
Hello I have 2 aw8002t amps I want to run them at 4ohms to get the 800watts out of them (really like 750 watts) so I was wondering if you guys could recommend me 2 - 12" subs that would work great with these amps I am going to connect one amp to each speaker want to spend $400.00 maximum on both subs the cheaper the better. Looking for the hard hitting bass that will vibrate my seats I like to feal the bass. Also can anybody tell me around what level should I set my gain to feal some of the mids hitting to. Before I had to 12" audiobahn 400 rms subs running of a boss amp 1200 watts bridged and for being a sh|ty systems I know I know that damn system vibrated the hell out of my seats was'nt that loud outside the car maybe becuase it's an acura but I loved the vibration. Probably becuase I overpowered the subs I dunno. But seeing from the damn good advice you guys give I believe you guys know best. Please and thank you for any help ----- (I posted this same thread in the subwoofer forums but will check both forums for reply's thankyou again)
Username: Tjmutlow
Post Number: 1454
maybe a comp vx dual 2ohm, they need 750 rms, or Alpine swr-1222d subs
rochester2580
Thanks TY have you ever had any experience with either one of those subs
