planning on upgrading from the type R. stuck between jl w6, aa arsenal, and idmax, plan on sticking about 600 watts on one of these subs, am an sql fan. The arsenal is pretty tempting because it is so cheap, has anyone heard all of these subs and is aa really all what it is cracked up to be. A ranked order of these subs based on sql would also be appreciated. thanks
no 600 @ 2 ohms its the alpine mrd-605 seems to run pretty clean power though. for 160 that aa is tempting. have you had any experience with either the jl's or aa's?? which sub would you recommend??
ive heard the w6 but never heard the arsenal....ive heard good things about the arsenal and it is alot cheaper...so i would have to go with the arsenal
