New member Username: ImportMaple shade, Nj Usa Post Number: 5 Registered: Feb-06 | i have a 12" l5 in the kicker box and my cuzin wants to trade me for 2 12" kicker comp crv's wit a box. should i trade or upgrade my l5 to a l7 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5321 Registered: Jul-05 | L5=CVR in SPL and the Cvr kills the L5 in sq, and 2 of them would muder the L5. Also 1 L7 would not get as loud as the 2 CVR's..But what kind of amp do u have, that makes a big diffrence |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5324 Registered: Jul-05 | |
New member Username: ImportMaple shade, Nj Usa Post Number: 8 Registered: Feb-06 | rite now i have a 1200 watt sony xplode and im goin to get a kick amp that is goin to fit in with my subs perfectly |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5325 Registered: Jul-05 | k sounds like u are getting a great deal, but what are the vc configs on those CVR's just to make sure they will match up with ur amp |
New member Username: ImportMaple shade, Nj Usa Post Number: 10 Registered: Feb-06 | wat do u mean when u say "vc" thanks |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 600 Registered: May-05 | he means voice coil EX: dual, single, 4ohm , 2ohm |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 11 Registered: Feb-06 | oh there dual 2ohm |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5327 Registered: Jul-05 | ok which kicker amp are u looking at??? |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 12 Registered: Feb-06 | dont know yet but will it work with the amp i have rite now. I have a sony explode . http://www.circuitcity.com/ssm/Sony-2-Channel-Xplod-Amplifier-XM2200GTX-/sem/rps m/oid/86765/catOid/-13095/rpem/ccd/productDetail.do |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5328 Registered: Jul-05 | Whoa, the real bad thing about that amp is not that its Sony.lol but that its not CEA rated so those numbers could be b/s if u got the cvr's wire each sub in parallel Also u really need to get rid of that thing asap |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5329 Registered: Jul-05 | Wire ur voice coils in series, and ur speakers wired in parallel. Until u get another amp u will serverly be underpowering the cvr's |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 13 Registered: Feb-06 | the amp seems to power my l5 nicely but i think u would know better so i will change it. But over all i should trade the l5 for the crvs rite? |
Silver Member Username: PelonaPost Number: 505 Registered: Dec-05 | you should get the 2 crvs and use this amphttp://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=282 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5332 Registered: Jul-05 | overall yes, ur kinda rippin ur cuzin off.lol but dont tell him.lol |
Silver Member Username: PelonaPost Number: 506 Registered: Dec-05 | what? |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 14 Registered: Feb-06 | so if he takes mah l5 out and puts in a l7 will he beat the crv's in sound |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5333 Registered: Jul-05 | I would get this amp http://ikesound.com/product-product_id/2424 Since u have 2 run at 2ohms anyway, it puts out its rated power, nice build, good quality, great price, also when ur ready to upgrade u could get 4 ohm subs and wire to 1 ohm |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5334 Registered: Jul-05 | nope if u get this^^ There would be no way he would be able to beat u with 1 L5 or 1 L7 |
Silver Member Username: PelonaPost Number: 507 Registered: Dec-05 | you cheap b_stard |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 16 Registered: Feb-06 | pelon that amp u recommened to me, is that perfect for the 2 crv's |
Silver Member Username: PelonaPost Number: 508 Registered: Dec-05 | and the square solobarics have one of the worst sq in car audio. get the crvs. |
Silver Member Username: PelonaPost Number: 509 Registered: Dec-05 | its perfect. you can get the amp cheaper though. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5335 Registered: Jul-05 | "you cheap b_stard" Are u refering 2 me??? |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 17 Registered: Feb-06 | ok thanks i will indeed trade. thanks for all the help u guys p.s wat does sq mean lol |
Silver Member Username: PelonaPost Number: 510 Registered: Dec-05 | yes |
Silver Member Username: PelonaPost Number: 511 Registered: Dec-05 | sq=sound quality spl=loudnes sql=sound quality+loudness |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 18 Registered: Feb-06 | how much cheaper can i get that amp |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5337 Registered: Jul-05 | sq=Sound quality (how good it sounds) spl= Sound pressure level (how loud it gets) Sql= Sound quality level (how good it sounds while getting loud) |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5338 Registered: Jul-05 | even if u could get that amp for 200 i would still get the viper |
Silver Member Username: PelonaPost Number: 512 Registered: Dec-05 | heres one on ebay just a little bit cheaperhttp://cgi.ebay.com/ebaymotors/KICKER-KX850-2-CAR-AUDIO-2-CH-AMP-AMPLIFIER-1700- WATTS_W0QQcmdZViewItemQQcategoryZ38638QQitemZ8038118859QQrdZ1QQsspagenameZWDVW |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 19 Registered: Feb-06 | ok hold can 2 l5's or 2 l7's beat 2 crv's |
Silver Member Username: PelonaPost Number: 513 Registered: Dec-05 | is that viper good chauncey? its just that when someone says they want a cheap budget amp, they always choose one of those viper amps. i would recomend the kicker so he could keep everything kicker. |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 20 Registered: Feb-06 | what kind of battery will i need and will i need a capacitor |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5339 Registered: Jul-05 | 2 L5's nope 2 L7's yes in spl no in sq |
Silver Member Username: PelonaPost Number: 514 Registered: Dec-05 | capacitors are useless. you should upgrade your alternator first. the heart of your electrical system. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5340 Registered: Jul-05 | Viper, Orion, Directed are all the same company, so yes that is a great amp. I like the idea of everything kicker but with the Viper he has more flexibility. Also u will need a High Output Alternator not a battery or a cap. |
Silver Member Username: PelonaPost Number: 515 Registered: Dec-05 | are all viper, orion, and directed underrated amps? |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 21 Registered: Feb-06 | k thanks for the help imma go trade rite now. That decision took me days |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5342 Registered: Jul-05 | I wouldnt say they where underrated, but they do put out there rated power, 1200rms is 1200rms |
Silver Member Username: PelonaPost Number: 516 Registered: Dec-05 | i know the orion 2500d is underrated |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 22 Registered: Feb-06 | so a higher wretch or more powerful battery wont affect mah system |
Silver Member Username: PelonaPost Number: 517 Registered: Dec-05 | you could get a good battery too if you play music with the car off for long amounts of time. when your driving its the alternator thats important. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5343 Registered: Jul-05 | Read http://wickedcases.com/caraudio/charging.html http://wickedcases.com/caraudio/capacitors.html |
Bronze Member Username: ImportMaple shade, Nj Usa Post Number: 23 Registered: Feb-06 | k thanks |
Silver Member Username: PelonaPost Number: 518 Registered: Dec-05 | why does it say "the homepages of glasswolf"? is that his site? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5344 Registered: Jul-05 | yep, thats his site |
