Speakers won't work after burning smell
Hi All, I am hoping somone has a clue as to what I need to do after my car speakers stopped working today. The stereo still looks like it is working but no sound is coming out. This occured after I started smelling a pretty harsh burning smell. I couldn't pin point the exact spot of the smell. Would the problem be the speaker it's self or just a wire or something? Ay help would be greatly appreciated.
Username: Alteraudiousa
Concord
Post Number: 114
if you're smelling a burnt smell if its coming from the speaker you probably burnt the voice coli which means the speaker won't move. Can you see if it moves or not.
Username: Solacedagony
New Jersey US
Post Number: 792
You clipped your speakers to death probably.
LoriH
OK- i'll check to see if the speakers will move but if the coli is burned does that mean I have to get new speakers or just a new Coli?
What does "clipped my speakers to death mean?"
Clearly I don't really know ,much about this stuff!
Thanks for the info guys!
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10934
does the smell come from the region of the speakers, or the radio itself?
that should be easy to tell.
lorih
The smell came from the rear speakers.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2099
likely how it went down: http://www.realmofexcursion.com/videos/Various/coilburn.1.wmv
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10945
clipping explained:
http://www.bcae1.com/2ltlpwr.htm
Username: Rideredder
Cornell, IL USA
Post Number: 199
Actually, he spelled it wrong, beings it seems you don't actually know what he is talking about, it is a voice "coil" , not coli.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10963
don't want any e-coli in your voice coils.. that's for sure.
Concord
Post Number: 126
There is no way to replace a VC without admitting to the manufacturer you messed something up and then they basically charge you for a new set of speakers. Its better just to look into getting new speakers.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10979
in many cases, true.
some speakers have replaceable coils (peerless tweeters, solo X sub, etc) and some companies under warranty will replace the driver. The cost to rebuild a driver most times though, is prohibitive unless you spent $500+ on each speaker.
