Settings..
Username: Shawnomak
HB, SK Canada
Post Number: 191
I got my box built.. its 2, 2 cubic foot chambers, ported tuned to 35 hz. My amp is an Infinity 310A and id like to know what to set the gains to.. lpf etc.. I heard you're susposed to set something lower than the box tune, but i forget what it was and i cant find anything. Anyone wanna help me out?
Username: Shawnomak
HB, SK Canada
Post Number: 192
do i set the lpf 10 under what my box is tuned to?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2060
set your LPF to ~80hz
subsonic filter just below box tuning
set you levels on your HU to flat and turn the volume up 3/4 of the way. the run tones to the sub and turn the gain up until you just hear distortion...then turn it down just a hair.
