Down Firing Subs
Username: Shadowfox1290
first off what is the real advantage/disadvantage to this
i have an old 12" pioneer sub and it seems like you can onl;y "feel" it within 7-8 feet of it you can hear it but not really feel it beyond that is this normal
it is powerd by my reciever with 220 watts
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10894
firing the sub downward can use the vehicle to resonate the output.
you need a sub tht's designed to be mounted that way though. you need to calculate the "sag" of the driver's suspension to see if it'll work.
Percentage of Sag = 24,849 / ( Xmax * Fs²)
If Sag% < 5%, the driver may be mounted down (or up) firing. (Xmax in milimeters.)
*Glassie drops the knowledge
Username: Pelona
Post Number: 341
you got your sub powered by the reciever?
220 watts. Thats a pretty strong reciever you have there. LOL
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10908
that sub needs a deditaced amplifier.
no radio in a car will put out close to 200 watts.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1744
i never knew that only some subs (probably most though) can be mounted up or downfiring
Username: Nocc1n
US
Post Number: 181
glasswolf is awesome
Username: Phuktupbasshead
Phoenix, Arizona United State...
Post Number: 404
you confused me on that equation there...
please clarify.
24,849 divided by (xmax in milimeters)? What's the *Fs for?
sorry, please explain.
Thanks.
Username: Solacedagony
New Jersey US
Post Number: 801
Fs - This parameter is the free-air resonant frequency of a speaker. Simply stated, it is the point at which the weight of the moving parts of the speaker becomes balanced with the force of the speaker suspension when in motion.
Can get that usually from the manufacturer's website.
Not sure about what format the Xmax should be in.
* = multiplying
So 24,849 divided by the quantity of Xmax multiplied by Fs squared.
"*Glassie drops the knowledge"
Haha GhettoGlassie in the hizzouse
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10981
what he said.
Fs is listed in the TS specs of the driver, available with the speaker or from the company's website most times.
