How About This Amp??
steinkea
I am thinking about getting a profile AP1200 amp and am wondering if it is a good amp and what subs i should get for it?
Username: James1115
Ct
Post Number: 4897
no its not a GOOD amp. will it work on a budget? yeah sure it will but it is not GOOD by any means. Also it will not put out anywhere near the max power ratings they claim just to let you know.
steinkea
will it put out the 300w rms x2 @ 2 ohms like it says or no?
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 364
James said it was overrated so it will put out "less" than what it says....so maybe 200-250 rms
Username: James1115
Ct
Post Number: 4900
if your lucky!
steinkea
he said it wont put out the max. i was wondering about the RMS output.
Username: Tjmutlow
Post Number: 1380
How much are you trying to spend?
steinkea
he said it wont put out the max but I was wondering about the RMS output.
steinkea
I am trying to keep this as cheap as I can.
steinkea
I am trying to get a subs/amp combo for around 500 that will still be loud.
Username: James1115
Ct
Post Number: 4902
is ebay a option?
steinkea
I have never worked with Ebay but would be willing to.
steinkea
bump
steinke
What about this?? would this sound decent or would it just be a waste of money?? http://cgi.ebay.com/2-Audiobahn-AW1251T-SUBS-CAP-SUB-BOX-AMP-KIT_W0QQitemZ586101 1587QQcategoryZ48613QQrdZ1QQcmdZViewItem
Username: Tjmutlow
Post Number: 1381
not bad for a starter set for 350 delivered
steinkea
Do you think it will put out the RMS values that it says??
Username: N2audio
Lawrence, Ks USA
Post Number: 540
outside the ecoustics world Profile is often recommended as the best budget amp you can get. If not accurately rated, very close.
There are multiple reviews at sounddomain.com and caraudio.com, and the positives outweigh the negatives by a LOT.
Check out millionbuy.com for great prices, or profilecaraudio.com if you're open to buying a refurbished amp.
steinkea
any other suggestions for a cheap start up system that will be loud??
steinkea
bump
