4 jlaudio 12 w6v2 and confused
Username: Toomuchsound
Staten island, N.y. Usa
i have 4 jl audio 12 inch w6v2 subs in a sealed box and i have a jl audio 1000.1 amp.
does anyone know if this amp will do the job or should i get another amp.?
please can someone help that knows about this amp
Username: Madeupname
Post Number: 145
id go with another 1000/1
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5016
i would go with another amp but funds are low.
i would get 1 more if i find 1 but this amp is expensive.but do ya think it will pound jus with that amp?
Username: Rovin
Trinidad & T...
Post Number: 5322
thats 250wrms/sub - should sound alright but do $ave for another 1000/1 like they said....
Username: James1115
Ct
Post Number: 4878
If you plan on running 2-1000/1's, and your orion 4 chan 1000 watt amp I hope you have cash for a serious serious serious alternator upgrade!
Los Angeles, CA USA
Post Number: 2280
i would just go with 2 subs for now until you can upgrade your alt and get another jl1000/1.
