New member Username: Night_mirageTexasUSA Post Number: 3 Registered: Jan-06 | Hi guys i 'm new and i have kicker kx1200.1 what is the perfect subs i want two . price 150$-200$ for both . MTX or Kicker or JL Audio thanks |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1310 Registered: Dec-05 | rule out mtx , they're not good subs , umm you could run 2 kicker 10'' l7's |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1311 Registered: Dec-05 | if you wanted one you could run a mtx 9500 or a 15'' kicker l7 |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 497 Registered: Jul-05 | you can get type Rs for under 130 each. |
Bronze Member Username: JkidderSpring hill, Florida Usa Post Number: 58 Registered: Nov-05 | ill sell u 2 10" L7's brand new in box for 260... let me know mahde |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 345 Registered: Oct-05 | yea, just rule out mtx. i would go with some comp vr's because the L5 series is not very good for sq and its hard to listen to the highs. If you are going to findd some subs within that price range it is going to be very difficult. try ebay and look at some comp vrs or type r's. both very good subs. are you looking for 10's or 12's?? |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 346 Registered: Oct-05 | also if you want the 1200 watts into both subs, you need to get dual 4 ohm subs. and wire them into a 1 ohm load. |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 347 Registered: Oct-05 | i mean 600 watts into each sub. that amp also puts out like 1340 watts or somethin |
New member Username: Night_mirageTexasUSA Post Number: 5 Registered: Jan-06 | thanks all of you okay i will stay away from MTX so what i would buy . i want 10" just two . i am watting |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1207 Registered: Aug-05 | 2 12" Assassins? |
New member Username: Night_mirageTexasUSA Post Number: 8 Registered: Jan-06 | okay i want two subs between 200-300 for both 10" or 12" it does not mater . thanks |
Silver Member Username: 420pimp2Post Number: 207 Registered: Jan-06 | spend the extra money and get some eclipse ti's |
Bronze Member Username: Night_mirageTexasUSA Post Number: 17 Registered: Jan-06 | I WOULD LIKE KICKER OR AUDIOBAHN OR JL AUDIO |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4787 Registered: Jul-05 | well u cant afford jl audio with that amount of money, Audioburn is crap, so i guess u will go with kicker Also is there a reason u only want these brands??? |
Bronze Member Username: AlteraudiousaConcord Post Number: 40 Registered: Jan-06 | hmmm...you ask for a perfect sub yet restrict the choices to 200$ or less and not too many companys to choice from. I'd get a Dayton MKIII before anything mentioned or an Elemental Designs Kv.2 series. Broaden your horizons and get your self out of a stupid store thats worries how much you will contribute to their kids college funds instead of finding something good. |
Bronze Member Username: Night_mirageTexasUSA Post Number: 19 Registered: Jan-06 | okay i can make it 300$ for each sub 600$ or less any company . i don't know alot of subwoofers company i just know kicker jlaudio audiobahn alpine boss hifonics jbl just that so i 'm watting for u . |
Silver Member Username: ThigpenRVA, Va Usa Post Number: 460 Registered: Sep-05 | for around 1300 watts my vote goes to either 2 RE SE's (www.reaudio.com) or 2 Type R's, not sure on the pricing of the SE's anymore but you can get 2 Type R's off ebay for around 220 or so. for a little under 300 a sub, you could also get 2 12W6v2's or 2 12" IDMAX's which would both make really nice systems. |
Bronze Member Username: Night_mirageTexasUSA Post Number: 22 Registered: Jan-06 | jl audio is high price and i need two for kx1200 but type R is Good . i will wait all of idea . |
Silver Member Username: 420pimp2Post Number: 218 Registered: Jan-06 | i heard in another thread that eclipse ti's get louder then the re,se's and have a lil bit more sq. And alpine type'r's dont evan compare. Is this True? |
Gold Member Username: CenusHicksville, Ohio Usa Post Number: 1125 Registered: Jan-05 | well if you want to use kicker wait untill the new cvx comes out and get those, but i'd recommend some eclipse ti's, and ti's are as loud if not louder than the re sx so yes they are louder than se's and the sq would probally be about the same. |
Bronze Member Username: Night_mirageTexasUSA Post Number: 23 Registered: Jan-06 | thanks and i'm watting but copmvx 12" is 700RMS can kx1200.1 push two of cvx 12" thanks |
Gold Member Username: CenusHicksville, Ohio Usa Post Number: 1127 Registered: Jan-05 | ya the 1200.1 is underrated so it puts out around 1350 watts, so i would say it should work perfectly. |
Bronze Member Username: Night_mirageTexasUSA Post Number: 27 Registered: Jan-06 | Thanks for your interesting .. Dustin |
