Which RE sub?
Username: Titanbk
Mansfield, CT USA
Post Number: 62
I have decided to go with an RE sub for all out SPL. Now should I go with 2 RE SX 15's with 2 re 12.1s? Or now I am thinking 1 RE XXX 15 with either Kicker 2500.1 or Orion 2500.1. I am using right now a 5 cu. ft. ported box, I have a HO alt and 2 batteries. What do you think? I want to make the jump over 150 dbs. this season.
Username: Thigpen
RVA, Va Usa
Post Number: 459
the XXX is about as loud as a single SX, maybe a little less, but has better SQ(from what ive been told). If you want all out SPL, get an MT.
Username: Titanbk
Mansfield, CT USA
Post Number: 63
I am just alittle worried about getting a sub without a warrenty is all.
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 45
Sx's are supposedly louder than w7s. I have two 12s in a 5 ft^3 tuned to 33 hz and it blows me away. But then again I'm in a single cab truck... But heck, they pound. Get two.
Username: Titanbk
Mansfield, CT USA
Post Number: 64
So from what thigpen said it makes it sound like the SX is better for SPL than the XXX. Is this the case?
Username: Pelona
Post Number: 268
yes the sx is better at spl than the xxx and the the xxx has better sq. but they both have great sq and spl.
Username: Titanbk
Mansfield, CT USA
Post Number: 65
Which is better to run to a RE SX? Kicker 1200.1 or the RE 12.1?
Username: Solacedagony
New Jersey US
Post Number: 768
If you want SPL, you should definately go MT. An X.X.X is going to be about as loud as an SX because the X.X.X has higher power handling.
Username: Titanbk
Mansfield, CT USA
Post Number: 66
is it worth it to buy the MT even though it doesn't have a warranty? I'm not exactley the richest guy in the world and if it blows I dont know whether it will be time and cost effective to replace it before the next show. Whats the power rating on th e MT's?
