Anyone isntalled head units on 92-99 tahoe?
When i got my installation kit there was only a kit for my aftermarket cd player which goes where the stock radio used to be on my 98 tahoe. But below the AC knobs is where the cd player is located in this years model of tahoe. I was wondering if anyone knows if there is a slide in insert or cover for this CD player area?
Username: Illuminator
Post Number: 2465
There should be. In fact, i'm surprised you didn't get one. You might want to go back to the place that you purchased the installation kit from and ask them about it.
Philipp
Yes there is one, I had one in my 97 tahoe, I think it came from G.M. though. check online for one.
BrianR
92-99 Tahoe has the same system as my 98 Suburban....I think. Is there a factory amp? Any special wiring other than the adapter to the factory harness?
