What does it mean
Username: Curious
Post Number: 9
Ok guys i will go with the alpine type r's here they are http://cgi.ebay.com/2-NEW-ALPINE-SWR-1242D-12-DVC-4-OHMS-1500W-SUBWOOFERS_W0QQit emZ5860045414QQcategoryZ18803QQrdZ1QQcmdZViewItem but i don't get the dual voice coil 4 ohms thing are these going to work with my kenwood amp.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1439
is ur amp @ 1 ohm or 2
Username: Tjmutlow
Post Number: 1297
is your amp mono or 2 channel, and is it 1 ohm or 2ohm stable. that will determine the subs you need.
