Tweeter?
Username: Clacla100
Tallahassee, Fl US
Post Number: 46
i just got a set of tweeters with built in crossovers. Will it damage the radio if i just wire them in with my front speakers? i was just planning on taking the front right speaker positive and negative and joining one of the tweeters with that, then the same with the left.
Username: James1115
Wilton, Ct
Post Number: 4637
depending on how you wire them and the impedence of your current speakers and that of the tweeter you might be showing your deck a 2ohm load or lower parellel, or series a 8ohm load or higher. I wouldnt do that but its your system do what you want!
Username: Pelona
Post Number: 181
these cuspid tweeters are 4ohm but you could still hook them up to each speaker which will give your deck a 2ohm load.
i dont know why it works but it does. http://cgi.ebay.com/ebaymotors/NEW-2006-600-WATT-NIOBIUM-DIGITAL-CAR-STEREO-TWEE TERS_W0QQcmdZViewItemQQcategoryZ40019QQitemZ4606495379QQrdZ1
