Does this look right?
Username: Matt12490
Benicia, California
Post Number: 344
I'm still not sure how a distribution block works.. I drew an example is this correct??
http://i17.photobucket.com/albums/b56/thefirmm111/newpic.jpg
this is the product: http://www.knukonceptz.com/productDetail.cfm?prodID=BC-1428
Username: Matt12490
Benicia, California
Post Number: 345
I saw it in someones install and thats what it looked like what was going on.
Username: Rideredder
Cornell, IL USA
Post Number: 198
Yes, that is what a distrution block is. It distributes power from one big wire to two same size (or smaller) wires to power multiple amps.
Username: Homegrowncam
Watauga, TX United States
Post Number: 168
Um those are fused distrubution blocks. It doesnt say they come with the fuses or not. I know my tsunami block didnt come with the fuses.
