About to buy new subs
Username: Davidalexander
Graham, Texas Us
Post Number: 21
i know there are a lot of audiobahn haters around here but i think the 12alum is diff ive owned it and really liked it but i was wondering about the type r and which you all would recommend im looking for sql and any othere ideas on a sub about that price range with that kind of sql.
Username: John_wash
Nashville, Tennessee
Post Number: 122
type r is just right. especially compared to audiobahn.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1087
type r is really good at the price they're at , but if you wanted to dish out a little more money id say re se or jl w3
Username: James1115
Wilton, Ct
Post Number: 4658
I have a avalanche brand new 12 if you are interested in it:-) it will destroy the type r in spl and retains very good SQ at the same time.
Graham, Texas Us
Post Number: 23
how much for the avalanche? because the new ones are out. and sound wise how much difference would the type r be from the audiobahn because ive never heard the type r and i loved the alum when i had them
Username: James1115
Wilton, Ct
Post Number: 4666
much different! the new AA's are out but they are not XBL motors like the old avalam=nche's are. If you don't know the XBL the brahma uses it along with the REXXX.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4671
do u want sq, spl, or sql. and whats ur budget
Graham, Texas Us
Post Number: 24
sql about $150 $200 shipped (per sub)
Post Number: 4673
and u want 2 12's???
Graham, Texas Us
Post Number: 25
yea if my amp is big enough 1200watts at 1 ohm but im also thinking about buying a bigger amp
Post Number: 1122
a couple w3's
Username: James1115
Wilton, Ct
Post Number: 4668
what amp do you have?
Graham, Texas Us
Post Number: 26
audiobahn 1300hct
Graham, Texas Us
Post Number: 27
what about rockford p3, eclipse sw8122,vega v-max, re se, and the ones already mentioned which would you all pick for a sql
ps thanks for everything
Post Number: 1136
not sure how much they are but diamond d6's
Post Number: 4676
the eclipse, d6, and se would be ur best choices
Post Number: 1141
yep couldnt go wrong with any of them
