Phase?
Username: Luke5513
Post Number: 19
what is? and how do you test the phase of subs?
I have two infinity perfect 10.1 subs in a sealed box with a audiobahn a8000t amp. wired in 2 ohms. The subs sound like sh!t. the tecs at audiobahn told me to check the phaseing of the amp. It has a phaseing switch, witch is set at 0. It doesn't really make a differance when i switch it back and forth. any help would be great.
btw. I'm getting a new amp, it's going to take a month or so to save the money.
Just make sure all you connections are going to the correct terminals. Double check that the + and - from the sub are going to the + and - on the box and then to the amp. Make sure it is the same for both subs because if you accidently connected the + and - backwards on one it will make your subs sound crappy.
Username: Luke5513
Post Number: 20
thanks
