Thursday, January 19, 2006 - 20:08 GMT I have heard that the yellow top is not goos to use with sound systems. I will be using one battery, both for audio and starting, which onw should I get?
Username: Carguy Post Number: 5208 Registered: Nov-04
Thursday, January 19, 2006 - 21:11 GMT I wouldn't do that, but if you had to, get the yellowtop battery. Whomever told you yellowtop isn't good for audio needs some help.
Friday, January 20, 2006 - 00:48 GMT You would't do that? What would you do?
Username: Fandim Reno,
Nevada
United State...
Post Number: 588 Registered: Jun-05
Friday, January 20, 2006 - 05:31 GMT he wouldnt get a single battery for both starter and audio.
Friday, January 20, 2006 - 23:13 GMT Is installing a second battery cheap?
Username: Loc_out Post Number: 288 Registered: Feb-05
Saturday, January 21, 2006 - 00:06 GMT I wouldn't do that, but if you had to, get the yellowtop battery. Isaac why not?
