2 amps or 1?
Username: Bp317
Post Number: 18
alright for the time being im gonna hook up my 2 12" mtx8500's to my PA gothic series 1600. with the PA amp each sub will get around 400. I was thinking about selling the PA and getting 2 audiobahn a8002t or 2 directed 1500d amps. i want to put around 700 rms to each sub. would an amp for each sub be better? thanks
Username: Tjmutlow
Post Number: 1013
what is the voice coil config on those subs?
Username: Bp317
Post Number: 19
DVC 4 ohms
Username: Blainew
Post Number: 680
i would get 1 amp..youllget more power for you money bc with 1 amp you can wire the subs to 1 ohm
Username: Bp317
Post Number: 20
well, what are some good 1 ohm stable amps? because ive been looking at the hifonic bx and tx series, but from what ive read they only run at 70% of their rated RMS. thanks
Username: Blainew
Post Number: 689
orion makes good one ohm stable amps
alot of power for not too much money
orion 1200d = more than 1200 watts RMS @ 1 ohm
RE 12.1 = more than 1200 watts RMS @ 1 ohm
Username: Bp317
Post Number: 21
but what im thinkin is that 2 audiobahn 8000t, off of ebay, would be like $250ish. and most decent mono amps that would put that much cost around $300. i would think that the 2 would be more efficient.
Username: Tjmutlow
Post Number: 1122
you can run them, but they prob wont see 800w at 2ohms. 1 per sub
Username: Bp317
Post Number: 22
"you can run them, but they prob wont see 800w at 2ohms. 1 per sub"
? so you dont think that it would push 800watts at 2 ohms?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4527
That audioburn amp puts out 800 rms, they just have a poor build but it is a good budget amp
Username: Tjmutlow
Post Number: 1143
unless your running 14.4 volts the amp will not push that....
