Does Eclipse TI make low bass?
Username: Pelona
Post Number: 92
ive heard that the TI hits low but how can it if its made for a SMALL sealed enclosure?
Does it still make low bass in a small enclosure?
Dont you need a large sealed enclosure to get lower bass?
Username: Pelona
Post Number: 105
can anyone answer my question? jonathan?
Username: Sploosh56
Ohio
Post Number: 1090
go with a ported box tuned low like around 28 hz or 30 hz. Those subs sound amazing in ported boxes. I can design you one for $10.
Aol name Sploosh56
Email Sploosh76@yahoo.com
Username: Solacedagony
New Jersey US
Post Number: 747
If you want "low" bass you probably want a ported box, like Wahl said, with a low tuning. Also, subs with lower Fs' and I think the bigger diameter subs also help.
Username: Pelona
Post Number: 106
ported doesnt go as low as sealed. you guys should know that.
Username: Lil_jon
Post Number: 296
I thought the sealed would play lower and the ported will only go as low as its tuned to
and the sealed would sound better doing it?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 865
sure it does just depends where u tune it to.. you could tune it to 25 hz and hit the low 20's but why anything below 20 is inaudable so whats the point.. and i dont know many songs that have base in the low 20's.. but you are right it would be pretty hard to tune a box to like 10 hz lol while u could do it in a sealed box
Username: Pelona
Post Number: 108
Sealed has a better low end range.
Ported will have a steep drop at the tuned frequency. And you should always tune the box a little higher than the sub's Fs. And you should always set the subsonic filter around the tuned frequency to prevent damaging the sub.
Username: Pelona
Post Number: 110
now can anyone answer my question?
is the Ti able to hit low in a small sealed box like a normal sub is supposed to hit low in a larger sealed box?
or is the TI unable to hit the low notes due to its small sealed box?
