Will it sound good??
Sup ive never heard the cerwin vega vmx but i hear that they sound really good. Has any body had experience with these or ever heard of them?? Compared to jl audio would they sound about the same? Do they have good sq and spl?? Thanx ppl.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4364
there not even close to jl, about the same area as kicker cvr's with a little less spl and a little more sq
Username: Sploosh56
Ohio
Post Number: 1081
Depends on what Jl's you're comparing. The Vmax subs easily beat out the old W0's and those W1's. As for the W3's on up Jl has them.
thanx what kind of enclosure should i put them in?? I listen to alot of rap.
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1056
Less SPL than CVR's? I really find that hard to believe...The SQ I don't however :P
wut kind of enclosure?
