Clifford g5 alarm problem
Username: Ek9typer
Uk
hi just recently my clifford g5 alarm does not arm,the chirps that i normally here when i have pressed the button do not sound no more the doors lock but no chirps to let you no the alarm is activated,but after a while becouse the alarm has not chirped ,the alarm goes off ,can anyone help ,my alarm has remote start closure etc blue led if that help to
mike norton
you may want to send it back to the installer and make sure that they put the sealed valves in. looks like they did not. i know that must be the problem because i had the same occurence, and they fixed it. it should be free to do it.
