Jonathan / older RF amps any good ?
Username: Suleman36
Maryland U.S.A.
Post Number: 2840
Are any of these amps anygood or should i be looking at other amps ?
http://www.woofersetc.com/index.cfm?fuseaction=page.display&page_id=14&mfg_accou nt_ID=61&category_id=3
I like the look of the older punch amps like the 801s and so on..
Username: Suleman36
Maryland U.S.A.
Post Number: 2844
also the 800a from 1999 looks like a good amp since ive heard good things about them.
Which Arc Audio amp whould you suggest for a single ID MAX 12 ??? http://www.arcaudio.com/arc-05/amplifiers.htm
IM gonna order a ID MAX 12 online soon, do you know of a good place to order them from since cardomain has them on backorder ? Thanks
Username: Lil_jon
Post Number: 282
i have 1 alil older then those alot older i think 25 by 4 but i think it actually puts out close to twice that. seriously. It almost as loud as my eclipse amp 85 by 4. sound great with chep speakers
Username: Suleman36
Maryland U.S.A.
Post Number: 2845
Im gonna go with the ID MAX 12 / probably the dual 2 ohm versian so that i can have it wired to 4 ohm to match the amp and get the lowest thd out of the amp.
Jonathan / Whould your recommend sealed or ported for this ID MAX 12 ?
Heres what ID recommends
http://www.imagedynamicsusa.com/spec.php?type=encspec&id=IDMAX12D2%20V.3
Username: Suleman36
Maryland U.S.A.
Post Number: 2846
Here is the actual spec sheet pdf jonathan
http://www.imagedynamicsusa.com/pdf/IDMAX12-V3-D2-spec.pdf
Username: Jonathan_f
GA USA
Post Number: 5431
Ported, 2.5 cu ft net tuned to 25hz. That's how I'd go, anyway.
