Whats the best brand for wiring kits out there?
Username: Safa19
Post Number: 256
im looking for 2-gauge amp kit and i dont know if the brand matters or not because they seem to range in price quite a bit so there has to be a difference right? so whats the top 3 brands, im looking to keep it under $100 for power wire, ground, rcas and a couple feet of speaker wire thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4190
All wires are the same, I would just make sure i got a nice set of rca cables
Post Number: 4191
http://www.knukonceptz.com/
and
http://www.ebay.com
Username: Safa19
Post Number: 257
also if i have 2 amps and i have the small blue signal wire from the back of my head unit going to one amp what do i do about the other one?
Username: Safa19
Post Number: 258
I read some where that some power wires have a higher thread count that lets it carry more power is that true or not? (it was about rockford fosgate)
Username: Blainew
Post Number: 624
you can split the wire...
Username: Blainew
Post Number: 625
well ..dont ACTUALY split it...run the REM from the HU to the amps...then run sepaarte REMS from each amp..then splice the two to the one coming from the HU
Username: Safa19
Post Number: 259
so make it like a Y so that it breaks off to each amp? also what is a good brand for RCA cables?
Username: Safa19
Post Number: 260
what about a kit like this
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1458707/vpcsid/0 /SFV/30046/sret/1221322015222223224281212217282215212219286219216233290233234295 228227242229232245244237248243244
it has everything in it but im doubting the quality of the RCAs... will a 2 guage kit be enought for 1200watts rms (orion 1200D)??? thanks for the help
Username: Safa19
Post Number: 261
how can a battery like this...
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1333953/vpcsid/0 /SFV/30046/sret/1221322015222223224281212217282215212219286219216233290233234295 228227242229232245244237248243244
have such a high amp out put if my alternator only puts out 105?
Username: Tdbdadrummer
Post Number: 917
Any wiring kit works, just make sure, you get good RCA's like Chauncey said, HOWEVER, I don't see that even they're that important.
As really, wire still is wire.
Username: N2audio
Lawrence, Ks USA
Post Number: 271
"how can a battery like this...
have such a high amp out put if my alternator only puts out 105?"
Even the $40 cheapo's can produce a few hundred amps at ~12v for several seconds at a time.
An alternator's current output is limited by the number of windings in the case - while your battery produces current from a chemical reaction. As long as an alternator can provide enough voltage to keep the battery charged it can produce hundreds of amps of current for a few seconds at a time often over a span of 5 years or more.
Username: Safa19
Post Number: 262
wow didnt know that about batteries thanks...
but back to the wiring kit, does the size of the fuse matter? because i found a 2 guage kit that has a 60amp fuse and a 4 guage kit that has a 150amp fuse. Shouldnt those be reveresed since 2 gauge wire carries more power or would the 60amp be enought for an orion 1200D??
Username: Scubasteve
College Park, MD
Post Number: 851
Kicker and JL wiring is pretty nice, but I don't always get them, both are up there in price if you buy retail.
Username: N2audio
Lawrence, Ks USA
Post Number: 277
A 2 ga kit using a 60A fuse would make me wonder if it's really 2 ga wire. Some of the cheap wiring kits aren't exactly honest on the thickness of the wire.
But yes, a 2 ga wire can carry about 40% more current than 4.
helpful page --
http://www.bcae1.com/wire.htm
Username: Safa19
Post Number: 264
yea it is by power accoutics
can you check it out for me?
Username: N2audio
Lawrence, Ks USA
Post Number: 279
I put an email into PA regarding that kit. I'll let you know if they reply.
Assuming it IS truly 2 ga I would suggest purchasing the Sound Quest ANL fuse holder for another $6.25 and an ANL fuse (150 or 200A) for $3.15 along with the kit and you'd have a good sized wiring set up for less than $40 + shipping.
Username: Suleman36
Maryland U.S.A.
Post Number: 2818
www.knukonceptz.com
simple and plain.
Username: Safa19
Post Number: 268
yea but i need 2 gauge and they dont carry any by the foot
Username: N2audio
Lawrence, Ks USA
Post Number: 303
Got a very surprising reply from PA...
My email to them:
"I'm looking at the Kit-2G. I know some of the cheapo ebay wiring kits use smaller wire than advertised, and judging by the 80A fuse that comes with the kit-2g I'm wondering if that isn't the case on the Power Acoustik kits. Can you give me the acutal current capacity of that kit, or what it's specified rms power limit is? I would like to replace the 80A agu fuse with an ANL possibly as large as 200A and just want to be sure the wire in that kit is truely 2 gauge."
Their reply:
"Hello Justin,
IF your looking for good 2 gage wire then you will need to pay the money.
Reynaldo Chavez Power Acoustik
Power Acoustik Att: Parts Dept.
Technical Services
1550 S. Maple Ave.
Tel-(800)-832-4647 Montebello, CA 90640
Fax- (323) 722-1122"
Wow - talk about brutal honesty. Not something you hear a lot of these days.
