Ohm's....with these subs, what the match?
Username: Afroopuff
Post Number: 34
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14818
I want to power 2 of these as cheap as possible without killing quality. The amp that would match would be a 1 channel 1 ohm i think, right? i dont understand the ohm part, i thing i wanna stick with a mono hcannel, unless a dual will make it cheaper, which i can't imagine
Username: Tjmutlow
Post Number: 1009
you can use a 2 channnel, use it running stereo or use a 1 ohm mono amp, around 600w or so.
