Need help bad wiring phoenix golds
mattfromnywit12's
I have 2 Phoenix Gold 12 inch dual 4 ohm voice coil speakers in a ported 2 12 enclosure. Im pushing them with a 250x2 PEAK power Clarion amp.I dont know the ohmage or RMS of this amp, however i was wondering what the best method of wiring these 2 subs would be? The way i have them now i am only using one voice coil per speaker and the amp is not bridged.And it isnt really that loud at all in my Sundance...
mattfromnywit12's
everyone is so helpfull
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 820
what is the rms numbers on those subs?? id advise u get a stronger amp and DO NOT hook up 1 voice coil only on a dual voice coil sub.. that will kill it fairly fast no one can tell you how to wire it unless u know what the amp is stable at .. its probably stable down to 2 ohms so you would wire each coil in parallel on a sub and then to a channel on the amp
like this http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2&image.x=25&image.y=9 to each amp channel.. that is IF ITS A 2 channel amp.. if its a mono amp with 2 channels this wont work so u need to find more about it
