Quick box question
i build a box out of mdf wood. if i fiberglass it on the outside would it sound crappy? would it even make a difference?
Username: Chevydriver
Mason, OH US
fiberglass doesn't really do anything to the box. All it does is when you get done sanding it and all that, it makes the box look good, not like the wood look. The sound would still sound the same even if it was just mdf wood.
i thote that thanks, just wanted to make sure
Username: Scubasteve
College Park, MD
Post Number: 843
glassing the outside might stiffen it up, but could end up look pretty goofy. Also realize that fibreglass is weakest in long flat areas with little contour.
