Should enclosures be as big as possible??
Username: Blainew
Post Number: 626
im getting 2 RE SX's....each will be powered to 1200 RMS
should i put each in as big as an enclosure that i can fit in the trunk
are bigger enclosures better
and should it be ported??
i plan on having the box being made by klausaudio..so i just input the sq. feet then they make it
Username: Blainew
Post Number: 629
Username: Scubasteve
College Park, MD
Post Number: 844
yea, that SX is trying to be ported. Building a big box allows you to tune lower and decrease port noise while increasing output. But there's limits to the output gain you get by increasing the size of the box.
Username: Blainew
Post Number: 634
so..if i get two..how many sq. feet should each have..or should i just talk to RE
College Park, MD
Post Number: 846
I haven't spent any time working with that driver's specs, I'd give them a call. Also, you could take a look at a box program like WinISD or box planner and see what it comes up with. This will be usefull info to have when you talk with RE.
Username: Frkkevin
Fort Worth, Texas US
Post Number: 150
I'm doing two SX15s for my truck. 7^3ft and ports tuned to 28hz. They recommend 3.5-4.0^3ft per subs.
Heres the start of it. Ports are already in and rounded off to decrease port noise. Just have to cut the face plate to reveal them. Going to be another box around this covered and housing the amps. Should be nice when its done
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 437
What U Guyz Think Of A 4.189cuft Box Tuned Around 26.5Hz Or 26Hz With A 3Inch Wide Slot Port For 1 12 Re Sx Any ? Box.. 15H 34W 18D
Username: Frkkevin
Post Number: 152
Lowest I'd tune a 12 is 30hz ..
Username: Addicted2bass
Miami, Florida USA
Post Number: 1021
nope you don't want to build the biggest enclsoure possible, for one it'll choke off the airspace into the cabin if you're firing towards the rear and not allow the bass to travel inside your cabin. And also if the enclosure is to big then the sub will just react like its playing free-air, while also lower lower trhe power handling of the subwoofer
also not sure if you mentioned the driver size but we'll need that info to help you.
testing
Pgh, Pa Usa
Post Number: 438
i have like a 4sumthin cuft box tuned to 26.5hz wit 1 jl w3v2 an it sounds great it hits high an does the lows great an i think it sounds go0o0o0o0od it beated 2 15 kicker compvrs seald an 2 15 volfenhag seald an 2 alpine type rs 12s seald an i might b getti nit meter sunday hopefully
