3 JL 12W6v2 Amp
Username: Vc3
Post Number: 10
What amp would be good for 3 JL 12W6v2? Thanks
Username: Subsonic
Dunn, N.c.
a jl 1000/1
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4093
yeah^^, kicker sx 1250.1, Phoenix Gold Xenon 1200.1, etc
Username: Subsonic
Dunn, N.c.
yeah kicker sx 1250.1 and sh** .(JL 1000/1 ) same power from 1.5ohm to 4 ohm and from 11v-14.4v same power! kicker needs 14.4volts to get 1250watts@1ohm three JL 12w6v2 wired to 8ohm each will =2.7ohm load
Username: Tjmutlow
Post Number: 946
that amp will not push 3 12w6 correctly
Post Number: 4106
"kicker needs 14.4volts to get 1250watts@1ohm"
4 u to have such a nice system ur are sounding like a newb, it will reach 1250+ rms at 13.8 volts, btw i have 4 and love them to death. Also u do realize that the 1000/1 will only put out 500 watts @ 8 ohms so u will be seriously underpowering them
Username: Vc3
Post Number: 11
so if I were to get the kicker sx 1250.1 amp how much rms would each sub get? Thanks
Username: N2audio
Lawrence, Ks USA
Post Number: 250
--"u do realize that the 1000/1 will only put out 500 watts @ 8 ohms so u will be seriously underpowering them"--
He said 8 ohms each - I think we are to assume parallel wiring from there to = 2.67
The 1250.1 is a bad choice for this application - you'd be paying for 1200w+ and only able to get ~500 from it.
Los Angeles, CA USA
Post Number: 1782
optidriven how do you make the letters darker like that?
Username: N2audio
Lawrence, Ks USA
Post Number: 253
basic html code
[b][/b]
[i][/b]
etc.
use <> instead of brackets.
Username: N2audio
Lawrence, Ks USA
Post Number: 254
I guess I could have just enabled html code :-)
bold = <b>text</b>
italic = <i>text</i>
not sure what other tags work. It doesn't seem like very many.
Username: N2audio
Lawrence, Ks USA
Post Number: 255
**disabled
Los Angeles, CA USA
Post Number: 1783
thanks
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 515
the JL amp would be the best but wouldn't that kicker amp be closer to 1000 or like 900 watts @ 2.67 ohms
Username: Vc3
Post Number: 13
is there any amp i could get to fully power them or should I just forget about the 3 subs
Username: Tjmutlow
Post Number: 961
you could run the 3 on that JL, the optimum power for those subs is about 400-500w per sub, after that your heading into the danger zone for those subs(JLw6 and w7 can be power sensitive). i wouuld run just 2 of those on the 1000/1
Username: N2audio
Lawrence, Ks USA
Post Number: 260
--"wouldn't that kicker amp be closer to 1000 or like 900 watts @ 2.67 ohmsThe kicker's 1250"--
Not likely. OCS has it as 1250w at 2 ohms, which isn't correct. It's actually 1250w at 1 ohm, 625w at 2 ohms, so right around 500w at 2.7. Even considering Kickers are under-rated it couldn't do much more than 200w per sub.
Username: Redliner
Wilmington, Ma
Post Number: 507
y not just get 3 500/1 if you really want those three subs
eagle dont listen to chauncey hes just trying to get his post count up.
Like opti said that kicker its a BAD CHOICE.
Post Number: 4146
who cares about getting there post count up.lol, if u care about post counts so much why not register and post as much as u want
