2 L7 vrs Brahma
Username: Bga44
Tampa, FL
Post Number: 201
my friend has 2 kicker L7s 15". i have 1 15" adire brahma. he has a crappy amp and box. i have orion d2500 amp and a very nice custom box made to adire's recommendations. which would be louder and which would have better sq?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1037
well for the spl part idk it'll probally be close, but for the sq part i hope and pray that you are joking and allready know the answer, cause if you don't you have problems.
Username: Bga44
Tampa, FL
Post Number: 202
i figured brahma would kill in SQ. he has 1 15" now, and it wasnt even loud, and people say its loud. so idk wut the deal is. his box is a real POS.
Username: Bga44
Tampa, FL
Post Number: 203
but in SPL it would be pretty close? and like i said his box and amp arent near as good as mine
Username: Cenus
Post Number: 1038
Ya!?!
Username: Bga44
Tampa, FL
Post Number: 205
alright thanks for your help. i was thinkin about gettin 2 15" L7s,i think i made a better choice with the brahma
Username: Cenus
Post Number: 1039
well to be honest i couldn't really tell you, i'd take a guess and say that the L7's should be louder due to the more surface area, but install plays a key role.
