Advice on what to buy.
Username: Motocrazy125
I have two 12" duals-max watt=1100 watts.
and a 460 max watt amp.
I have about 250-300 dollars to spend and i want to make my system better, i want to keep my dual box if i get new speakers cuz it really looks really sweet(plus it took me and 3 of my friends an hour to get it in cuz it just would not fit)...any advice at all would be appreciated.
Username: James1115
Wilton, Ct
Post Number: 4524
what size is the box? sealed , ported, or Band pass? what kind of amp do you have?
My Subs----- http://www.bestbuy.com/site/olspage.jsp?skuId=7044085&type=product&cmp=++&id=109 9396976115
My Amp---http://www.bestbuy.com/site/olspage.jsp?skuId=6755594&type=product&productCatego ryId=cat03085&id=1087342241703
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 358
Dual is Jensen, Jensen can be horrible or ok all depending on what it is. Change out the amp for a good solid 300 to 500 watter like a Rockford Fosgate, Kicker, Infinity, or MTX and those subs should sound quite a bit better. Can't garuntee you how long they'll live, but if you kill them you can always upgrade.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4113
"I have about 250-300 dollars to spend and i want to make my system better"
Can u take it back^^
Username: Baseball1187
Columbia, SC
Post Number: 504
lol^^
for 300 you could START OVER and be a lot better off.
