Woofer wiring question
Username: Buddyleee5
Post Number: 109
just built my first box and put a wire terminal cup in hte back of the box. The box is a sealed sncloseure with 2 12" se's. its one big chamber. I am wiring the subs to a 1 ohm load and i was wondering how do i connect the speaker wire to the subs adn to the cup? i know is kind of a dumb question but i can't figure it out. the back of the terminal is just a screw and a nut. how many wires do i need as well?
Username: Rovin
Trinidad & T...
Post Number: 4496
wire it up like this & put the 2 ends to the cup's terminals
use this link 4 future reference
http://www.the12volt.com/caraudio/woofer_configurations.asp
Post Number: 110
ok so its one wire with each half of the wire on one terminal i understand that now... but how do i connect it to the terminal? there isnt a terminal. All it is is a screw with a nut to tighten on top of it. how do i attack speaker wire to that. do i have to put rings on it?
Username: Baseball1187
Columbia, SC
Post Number: 464
no lol... take the wrench that came with it and loosen the screw... then on the bottom (of the terminal, below the screw) there is a hole you stick the wire in and tighten the screw on the wire..
