Please help me find an amp
Will 18
I drive a 1997 Jeep Wrangler, I just bought a Kicker 12' Comp 4-OHM. It has dual voice coils, its power handling in watts is 300, and it R.M.S is 150.
I am wondering what wattage of an amp should i get, how many channels does it need for only one sub. Thanks alot for your help!!!!!!
I am also wondering if you have a good site to go to where you can buy amps for a good price. I am kinda on a budget. Thanks Again!
Username: Blainew
Post Number: 596
buy a mono amp that is rated at 150 watts at 2 ohms
you should be able to get that pretty cheap...
Username: Blainew
Post Number: 597
