Only one speaker will play
John Gemme
I set up my new component speakers in the front and i connected the amp and everything. The problem is that only one speaker will play then if i reverse the RCA's then the other speaker will only play. So only one speaker will play at a time depending on how the RCA;s are plugged in. I was wondering if anyone has had this problem or can tell me what the problem is. thanks
Username: Tjmutlow
Post Number: 647
dont revers, unlpug one, then if it plays, then plug that one in the other jack, if it plays, do the same for the 1st rca you unplugged. It could be an rca problem or a problem with the radio output. you can always use a y adapter if needed.
Username: Pelona
Los Angeles, CA United States
Post Number: 9
how about fixing your balance in your deck.
