Silver Member Username: Yamahabanshee1
Paulding,
Ohio
Post Number: 275 Registered: Jul-04
Posted on What should i set my subsonice filter, gain, and that other 1 at? My amp is Audiobahn A8002T amp pushing 2 12" Fusion PowerPlants in a ported box. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 144 Registered: Oct-05
Posted on just put the gain where it sounds right. i have that same amp and i have it around halfway. where it blends in with the music and the speakers |
Paulding,
Ohio
Post Number: 278 Registered: Jul-04
Posted on what about the SSF? |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 1483 Registered: Oct-05
Posted on subsonic filter should be set to whatever your ported box is tuned to. |
Posted on what actually does the subsonic filter do?? |
Silver Member Username: Tdbdadrummer
Post Number: 827 Registered: Aug-05
Posted on If your box is sealed, it's not a big deal, just turn it off. Set your LPF to between 80-85Hz though, no matter what. |
Paulding,
Ohio
Post Number: 280 Registered: Jul-04
Posted on ok thanks fellas! |
