MTX 9500 12 or W7 ?
Username: 2001aurora01
MTX 9500 12 or W7 is there really a big difference
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1903
9500 has some additional output.
W7 has superior build and sq.
big difference in favor of the W7.
Username: Homegrowncam
Watauga, TX United States
Post Number: 136
Yeah there is a big difference in teh two. MTX says that the 9500 kills the w7 but thats on paper. No way in real life would they compare. The w7 has amazing sq while the 9500 doesnt come close. The 9500 does get loud but doesnt sound good doing it. The w7 sounds amazing and gets loud too!
Post Number: 12
whats is sq? and what is so important about the sq. I thought a sub was just suposed to hit the low notes and get loud as possible.
Post Number: 137
SQ is sound quality and it is all how you like. I mean some wnat it to be super loud but what they use sound like thrash. Its all in preference.
Username: Baseball1187
Columbia, SC
Post Number: 372
the 9500 isnt that great. MTX only compares the 10" versions of the 9500 and w7.
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 199
trust me ..you'd wanna put out a little extra money and get a w7 unless you just want your sub to get loud and sound bad doing it
Post Number: 18
so i guess ill go with the jl's thanks. i just wish they didnt cost so much.
Username: Bahn_man
Lynn haven, FL US
my 2 audiobahn aw1206T's with a 2400 watt 2 channel audiobahn amp blew away 2 9500's with the same type amp.....mtx aint that great at all...., and mtx gets really distorted when you play them loud...mtx dont impress me...
Username: Spyder
Eglin AFB, Florida USA
Post Number: 221
Just to add....we had a guy claim up and down his 9500 12 would sound better then my setup... he is rethinking his thought patern right now....it didn't sound bad....but it wasn't that great either....to bad i am selling the sub.
