Mixing 10"s and 12"s for sq and Spl?
Username: Burnupthetrack
Elk River, MN USA
Would having 2 10" subs and then adding a 12" sub affect the sound? I know the 12" moves slower then the 10"s so would music / beats sound weird or off? I have two 10" Kicker CompVrs and i was looking to add either a 12" solobaric or a 12-15" CompVr? wondering if the bass would sound messed up cuz of the timing?
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 254
if you have a 10'' cvr then you have a 12'' solobaric which is a completely different sub wouldnt sound that good..i wouldnt suggest to do it
Username: B101
Queen City, NC USA
Post Number: 174
It should sound allright, I see what you are asking, If you do that setup, make certain that the 10s are own its on amp, and the 12s on their own amp
That is if you want a mix of sq and spl like u said.
It can be done, thats what Im saying. If you are trying to avoid getting a SQL sub,
