Would this amp blow my subs?
Username: Banginscrew
Post Number: 15
a kicker KX2500 for my 2 Alpine Type X's it would push around 1200 watts to each speaker but RMS is 1000 watts and i dont want my subs to blow they are brand new but tehy are only 4 ohms??
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1907
i know someone giving 1900 real watts to each of 4 x types. they can take it.
be wise in your tuning though. he's an expert.
Username: Tjmutlow
Post Number: 491
that amp only pushes that at 14.4volts.....
Los Angeles, CA USA
Post Number: 1406
you can't use that kicker amp for the type X. that amp is 2500wrms at 2ohms. your 2 type Xs will be a 1ohm load.
Username: Rovin
Trinidad & T...
Post Number: 3925
he's right ^^^
buy a Orion 2500D to power those Xs .....
