Pioneer 7600mp keeps resseting settings
Username: Apple_5002
i have just bought a 'PIONEER DEH-P7600MP'. everything works but everytime i turn on my car the equaliser resets to default and everything else, like the clock on it.
can someone PLEASE PLEASE HELP me out because iv ordered sub package and i dont want this problem.
thanks
john
Username: Tjmutlow
Post Number: 230
Wired wrong, constant not hooked up correctly, yellow wire is constant. the yellow from the radion is probably hooked to the switched power in car, use test light to check.
great!!
i switched the wires around, red connecting with yellow!
working now!!
thanks
Username: Aowen84
im having problems playing mp3's with the same head unit. have you managed to play them in yours? if so did you have to do anything in particular?
