Where
Username: Madeupname
Post Number: 125
where can i find a jl w6v2 h.o. box?
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 680
http://mobile.jlaudio.com/products_enclosures_pages.php?menu=2&page_id=19
In the upper right corner just below the web page link tabs you will see "FIND A DEALER" link (in red). Click on it and then input your zip code.
Or,
http://www.woodlawncabinetry.com/index.html
Or,
http://www.klausaudio.com/
Or,
Ask MO. He was looking at runnin a JL setup in a HO box. Maybe he knows a better place than the ones listed above.
Post Number: 126
im just talking about the box, i already have the sub
Orangevale, Ca. USA
Post Number: 681
Yes, but if you use the "FIND A DEALER" link you will be able to order one from your local JL authorized dealer.
From the looks of it, it seems that these boxes are special order.
They cost quite a bit, and they are custom for the particular driver(s) that you will be using. Thats why you cant find them on a shelf. The options are endless. JL makes like 20-30 different subs. You will have a hard time finding a place that carries that many different types of boxes (just for one brand) and then have a supply of each just waiting arround for you to come by and get one, not to mention one that is relatively close to your neck of the woods.
Post Number: 127
oh ok, thanks alot my bad on the misunderstanding
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 689
also, people sell the boxes on ebay sometimes if you are into the ebay thing.
