Old school hifonics amp help
Username: Terry6405
Sullivan, IN US
Post Number: 104
i have a old school atlas VII vari-power 400 watt amp. every time i turn up the volume, it goes into protect mode, how can i fix this? i took it apart and realized how little i really know about car audio. what should i do?
Username: James1115
Wilton, Ct
Post Number: 4351
has it worked in the past? are you sure the install is correct? could be a faulty ground, reversed polarity, power wire hooked up to remote wire, ect need more info.
Username: Carguy
Post Number: 5068
An amp can go into protection mode if over driven or under powered.
For example, the power drops below 11v or you set the gain/level to 1v and send 4v.
Username: Terry6405
Sullivan, IN US
Post Number: 106
it worked fine and i checked all the wires. it hardly takes any power b4 it goes into protect
i think the gain was fine about 2.5--matched with the HU
i just got a new battery and it didnt have enough power to make the alt drag
is it just broke?
Username: Terry6405
Sullivan, IN US
Post Number: 108
i figued it out, reversed polarity, they need to make all speaker wire diferent colors so you can esily tell b/w +&-
