Downfiring a sub
Username: Erowang
San Francisco, CA USA
Post Number: 18
CHeck out this downfiring sub enclosure:
http://www.bavariansoundwerks.com/product.php/II=411/_cid=
Is there any way to modify a normal enclosure to downfire? Maybe some sort of mount that will hold up the enclosure.
Username: Adas
Bradenton, Florida
All you need to do to downfire a box is either put 4 feet on the corners, or just like that box just make the 2 sides longer so that they come in front of the woofer 2" or so. The only thing is that your box might be a bit too tall for your trunk if you lift it up too much...
