Hifonics Goliath XX-3212 is it a good sub????
Username: Toxa21
Chicago, Illinoise US
Hi
I'm getting a system for my grand cherokee and was looking at Hifonics Goliath XX-3212 sub.
Does any one know about them, and what kind of SQ it has.
What amp should I use to push it with.
Thanks
p.s. I'm new to car sterios so bare with me plz
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 297
hifonics new subs are not very good at all...im not sure which one that is but theres alot better stuff for the money. i have a hifonics amp and im ok with it, but not thrilled by any means.
how much money are you willing to spend on an amp and subs?
Username: Toxa21
i was thinking spanding 400 to 500 on sub and same on the amp
What about nakamichi deks?
thanks
St. Louis, MO
Post Number: 301
you have alot of options with that amount of money. look into the RE SX or SE, treo tsx, JL w6, alpine type x, ID max.
i personally like clairon decks. ive never seen a nakamichi deck in person so i really shouldnt say if they are good or bad.
Username: Toxa21
Witch one of those will hit the hardest( I listen to a lot of metallica and that tipe of music)and it sound realy nice when the base hits realy hard.
I only what to have one 12 sub, with ported box no bigger then 2-2.5cf
Can i get base to hit hard if i spend 1000 on sub and amp?? I'd realy like for it to hit maybe 140db that be nice.
Thanks again
Username: Cenus
Hicksville, Ohio Usa
Post Number: 809
the re sx would probally be loudest of the ones listed, but its going to need a lot bigger box than 2.5cf, you could also look into the eclipse ti they are very good sql subs and only need about 700watts to get moving, and work good in small boxes.
Username: Toxa21
What about RE xxx? what kind of sq they got? where can i get1 and what amp i need to power it with
I can just wait for litl longet and get nicer system
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 106
go with the RE 12" MT
$385 in group buy which is over dec. 31
Username: Toxa21
where that at Trey Kirdy?
Username: Jarvocop
Saskatoon, Saskatchewan Canada
Post Number: 26
Just look through the subwoofer threads. You'll come upon a thread that is like Last chance RE sale or seomthing like that...really good deals
Username: Rovin
Trinidad & T...
Post Number: 3773
here it is
https://www.ecoustics.com/electronics/forum/car-audio/180508.html
Username: Cenus
Post Number: 816
your kidding me u would take a mt over a ti, granted a mt would probally get louder than a ti but the ti would kill it in sq, and i hope u have enough power to run a mt it takes at least 1500watts, and i hope u have a big enough alt. to keep that amp going.
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 572
an sx 12 would not need more that 2.5 cuft i had one in a 2.5 cft box and a 2.25 cuft box tuned to 35hz and it was amazing, with a an orion 1200D pushing it at 1 ohm. he could deff get away with it in a 2.25 cft box. especially if he likes metallica
Username: Cenus
Post Number: 817
ohh its the sx 12 i thought he was talking about the 15, anyway the 12 would work in that small of enclouser. but i would definatly look into the TI before the MT.
