Whats the Difference Between a Wedge and a Rectangle Box
Username: Mrmikelazott
Independence, Oregon This one
Post Number: 23
ive heard that an angled box is supposed to be better. im not really sure. is there any difference if the box is the same size, but one box has a flat front and the other box has an angled front? some guy at my college said that angled boxes sound better than just sqaure ones. is that true?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 682
i wouldn't think so, just as long as theres enough clearance behind the magnet for air flow and the box is bilt to appropriate specs.
Post Number: 29
thank you, thats what i thought. i really didnt think it made a difference.
Username: Ishkabobble55
Erie, Pennsylvania
Post Number: 136
im pretty sure it does. in a rectangle box the side the sub is on is flat and the side behinde it is, this makes it so when sound waves come from the sub moving towards the back of the box the waves hit the back and bounce back to the front and hit the front and the process continues until the wave dissipates. in a box with an angled front the waves come from the sub hit the back off the box bounce back towards the front hit there then they are moved into a different direction and pretty soon there bouncing all over the box from corner to corner and so on. so there is a difference
Erie, Pennsylvania
Post Number: 137
Username: Rovin
Trinidad & T...
Post Number: 3841
^^^ its a term called 'standing waves' - read about it some where
Can't remember if there's any audible difference but its a hell of alot more work 2 build a slant front box so 4 me i'll stick 2 my reg 90 degree front/back boxes ........
Username: Jonathan_f
GA USA
Post Number: 5105
In a sense what you're talking about is true. A perfectly square box will have standing waves, and a wedge front prevents this from happening. A rectangular box, not so much the case.
Username: Rovin
Trinidad & T...
Post Number: 3842
but will there be any audible difference or is it just a physics theory/scientific thing ???.......
Post Number: 31
yeah, will it be worth my time to do all the angle cuts? will it sound that much better?
