Pioneer AVIC-N3 parking brake bypass
Username: Marts895
anybody knows how to bypass the parking brake of the pioneer avic-n3? i've read from previous posts to ground the wire for the parking brake from the HU - will this still work?
Username: Tjmutlow
Post Number: 1926
no, no one has found a way to bypassn it yet
Username: Marts895
what about what another posting said about soldering together the solders on the chip? does this unit have mercury inside the board?
Username: Tjmutlow
Post Number: 1929
i have heard it is not exactly the same, and in any case that normally is done if you care about no warranties. it will void any warranty.
Username: Mobile_mike
All you have to do is peel back the silver sticker on the underside of the unit. It will say VOID after it is peeled off, then slide the black switch to the opposite position and ground the brake wire. After that your good to go. The navi and video will work on the fly.
