What's better a crossover or an amplifier?
Username: Panamanian
Panama cityPanama
Post Number: 82
Is better a crossover or an amplifier?
is it a must to have both?
does a crossover draw amperes?
thanks
Username: Rovin
Trinidad & T...
Post Number: 3697
All modern amps now come with built in xover so imo u really don't have 2 buy a separate 1 . They don't pull heavy current like amps do .
mono amps have low freq settings so u r cool there
multi chan amps have full/mid/low freq settings too
U can also u a pre-amp if u like 2 change your setting very often from your dash .
http://www.crutchfieldadvisor.com/S-oTXtfTGbR2H/learningcenter/car/
Username: Rovin
Trinidad & T...
Post Number: 3699
Also certain higher models of HU come with subwoofer preout rca which makes things so much better cause its already separating the bass freq 4 u .......
Username: Solacedagony
New Jersey US
Post Number: 695
Everything electronic draws current.
A crossover and an amplifier are two totally different entities, you need each for different purposes. Generally, a crossover will complement the amplifier.
An amplifier amplifies a signal, makes your speakers run.
A crossover takes an input signal and generally break the frequencies up. Like on my amp for my sub. I have a LPF and HPF, so that I only run frequencies between about 20hz to 90hz to it.
As Rovin said, most amps come with built in crossovers.
